After a couple weeks of high water in the lake I boat in I finally got my pontoon boat back in the water, for about 20 minutes! The engine just quit, turned out to be the fuel line, BUT when I got it restarted I noticed no telltale, then telltale started but only intermittantly, before I could get back to shore, the engine went into overheat mode, I ran this way for quite some time till I could get a tow.
A few questions: Is this most likely the water pump impeller? Could I have damaged the enginge, I never ran over idle? Is this a job a shop could fix ( the water pump) in an hour of labor or so?
