New problem!!!
installed a new impeller, new t.stat with all new gaskets..
The motor started on the first crank. Up to 135F it ran smooth with super strong tale tale stream.
[FONT=Verdana, Arial, sans-serif]At 135F the stream became weaker where at 155F it almost completely stopped and the temp were going up rapidly. At 185F i turned the motor off. [/FONT]
I'm sure i installed everything correctly. It is not my first time i install impeller and t.stat.
Opened the cylinder hear cover and started the motor without it, No water coming from anywhere.[/FONT]
[FONT=Verdana, Arial, sans-serif]disassembled the lower to make sure everything was correct.[/FONT]
[FONT=Verdana, Arial, sans-serif]The impeller is good, the vines are in the right rotation, no slippage, the key is there. The t.stat starts to open approximately at 145F At 155 is is full open.
Any thoughts?[/FONT]
[FONT="] installed a new impeller, new t.stat with all new gaskets..
[/FONT]
