overheated engine beside pump what else could be wrong?
brownde
my water pump gave way and I overheated my 96 48HP johnson outboard. repalced pump, and replace a melted temp unit. The engine seems to want to start but won't any suggestion on what I should check?
Dave
AEROCOOK
Master Chief Petty Officer
Re: overheated engine beside pump what else could be wrong?
Check your compression to start with.
brownde
OK will do, but your scarring me.
Dave
danoutbard
Yep, overheating is never a good thing:facepalm:
boobie
Compression first. It's easy to blow a head gasket on an overheat especially if the temp sender was melted.
brownde
THanks.....how hard is it to replace ahead gasket?
AEROCOOK
Very easy. Just make sure you check the head for warpage.
brownde
THanks for the info and a big thanks for serving the country....
dave
