I overheated, no alarm, or warning. Water from two cyliners top and bottom. Compression test showed no compression on top and 120 on middle and bottom.
Look at the photo, see A... scoring from head gasket blowing, and B... a very small gap between the sleeve and the block.
Will these issues hinder the engine? Can I put new gasket on to check block? Why would I see water in the bottom cylinder but no visible gasket damage there.
Why no warning, or alarm?
