One day my outboard engine just started to alarm while idling toward the dock and no water coming out of the tell tail at idle. The smart craft gauge said it was engine temp. I thought no big deal I would replace the water pump impeller. I purchased a new impeller and removed the lower unit and removed the water pump housing. The old impeller didn't look that bad, but I replaced it any way. I checked the water inlet it looked clean. Put it back together and back in the water. Same thing would happen , no water out the tell tail at idle and I could watch the temp gauge rise. If I throttle it up above 1000 rpm it will start spurting water out the tell tail and the temp gauge will go back to about 145 degrees. I checked the thermostat and it is working fine. Pulled the fitting out of the engine that the fuel cooler and the tell tail hook into, the screen on it is clean. The engine runs fine at all rpms except the lack of water at idle rpm. I noticed that there is a lot of water coming up around the driveshaft in the front ,below the engine at higher rpms. I am wondering if there may be a hole in the pump discharge tube or something like that. I have the factory service manual for this engine, but it does not have a flow chart of the water cooling system. I do not see any water flow control valve in the manual either. Has anyone had a similar problem with this series engine? Does anyone have a water flow chart for this engine? I bought the boat used with about 700 hours on it and has 780 on it now. As far as I know it has always been ran in fresh water. The engine S/N is 1B3818**. I have searched the internet and haven't found much about this engine.
