1987 Suzuki 85DT. The motor runs and drives great up to about 3/4 throt. Than the alarm sounds. I can shut down and start back up immeditly and alarm is off and runs great at anything under 3/4. I have changed impella and has good water flow. I tested the thermostat and that appears good. I have looked at alot of past threads and there is much talk about a waterflow sensor. I have the manual for motor and can not find one. What I do have is a heat switch located between the 1st and 2nd spark plugs and there is a combination valve under the cylinder head for water flow. Could one of these be bad? Any help would be great.
Thank you
Thank you
