thundercat 9
- Oct 8, 2007
- 68
Hey guys,
I think I have a grounding "gremlin". At first, the volt meter on my dash started reading between 14 and 16 volts so I took my meter and checked the battery and sure enough, it was between 14 and 16 volts depending on the RPM of the engine. I put a new alternator in and still no change, the only difference now is the motor won't shut off with the key, but if I disconnect the (engine)Pink wire from the alternator white wire, the engine stops...The pink wire I'm talking about splits from one to two (one goes to the plug in wiring harness and the other goes to the coil).
Any ideas???:redface:
