preventec47
- Aug 7, 2016
- 17
Outside the box design for recreational inboard propulsion using lawn mower engines.
I am seeing a great availability of used "industrial" motors from Briggs Stratton, Kohler, Honda etc. between 8hp and 30hp and other
than paddle wheel drives I am not seeing any cheap easy solutions to get thrust from my preferred source......spinning propellers .
We need to rob cheap stuff off the shelf like drive shafts from cars and their U-joints or the mechanisms from front wheel drive
cars.... I think referred to as CVS ( constant velocity shaft?) . Also how bout centrifugal clutches used in go-karts and
maybe chain drive and sprockets and GoKart rear axles sticking through the transom with props connected to the wheel
hubs etc etc.
If we can figure out how to do this with perhaps scavenged parts off cars etc we can have complete prop propelled water
vehicles for hundreds of dollars instead of tens of thousands of dollars. Sure this stuff wont be "Marineized" but always
pulling it out of the water after use and slathering of oil and grease on the critical parts should slow the corrosion
down. We have to get creative! What are your thoughts ? I am not familiar with the old days but how did
the early pioneers build inboard shaft drive units ?
hubs etc etc.
