Outdrive wont go on.
Mickyski
Hi i took the alpha one gen one outdrive off of my boat to replace it with an alpha one gen one with the counter rotation option. The new outdrive will not slide on it gets to where the bolts start and needs about 3 more inches to slide on. The old outdrive still goes on no problem. Both have the same exact shaft. please help.
Chris1956
Is the shift cradle lined up? Perhaps the CR outdrive needs to be installed in reverse?
