I have an 84 Mercruiser 3.0 with an alpha one out drive I just replaced all of the bellows and the shift cable and the gimble bearing that the drive shaft goes through. I am now to the point of putting the outdrive back on and I am following the mercruiser instructions with the shifter and drive in forward and have vissually verified allignment of the the shifter setup I have the when I put the drive on I can feel the shaft splines engage and the drive goes almost all the way in but it pretudes about one inch and hangs up there. It acts like it is hanging up on the driveshaft orings that go into the gimbal bearing. The book says do not force the unit on
Does any one have any idea what I might be hanging up on or if there is something I am missing ?
Thanks
Thanks
