outdrive support
SeaRay245
does any know if i should be using a support to hold up the outdrive of a 84 merc 260 or will the pistions be enough i trailer it only 2 times a year
Ross J
Re: outdrive support
You can purchase a manufacturers product or make your own. Mine works fine, it's the last two rungs of an aluminium ladder cut of and placed between the tilt stop and the base of the tilt mechanism. It's worked fine for 5 years now. I wouldn't trailer without it as the stressors on a tilt/trim on the road are more sudden and jarring than when in the water.<br />Ross
