Outdrive Speed signal clean
Bourbonlover11
How do you clean out debris from the speed signal port in the lower unit. Do I run a drill bit into. If so how far. Will damage it. Thanks. Shawn
Bt Doctur
Re: Outdrive Speed signal clean
Easier to answer is we knew what drive
cliffblue
When mine packed in with vegetation, I pulled the line off the speedometer an attached my air compressor with the pressure turned down to 5-10 psi. Using a small drill bit, maybe 1/8", hand turned it until the plug blew out.
This is on a 2002 Mercruiser 5.0. Standard outdrive. Thanks. Shawn
Ayuh,.... Welcome Aboard,.... Is that a standard Alpha drive, or a standard Bravo drive,..??
