mikey.himself
- Sep 11, 2007
- 130
I have noticed near the end of the season that compared to my friends Bravo drives on his boat, my Alpha 1 has a fair bit of side to side slop on my rinker. What generally causes this? is it the steering arm that goes through the transom plate inside the boat generally? or is it a bushing on the bell housing? It's parked in a heated garage now and I haven't had a chance to check it out with a second person inside the boat looking for slop. There is no up/down slop, it's just side to side, and I got to thinking. If it was slopping while under load, would it cause your boat to sway back and fourth? Mine was doing it alot this summer once you got on plane and that's the only thing I can think of that would cause it. It's more than likely going to be traded in on a newer Cruiser Yachts 3070 Rogue which is bigger with twins, and all the bells and whistles. I'm still fairly new to outdrives unfortunately so bear with me. It may be that I just need to drag some unfortunate person up to the heated building to help me look at it.
1988 Rinker Fiesta Vee 280, 5.7L MERCRUISER Alpha 1
