Outdrive service
krudville
I put 3 qts of 75/90 in the lower fill hole. Probably spilled one trying to get more in. Does not register on the stick yet. Curious why we can fill from the top?
krudville
Sorry. Meant why can’t we fill from dipstick/too
Ayuh,,...... What outdrive,..?? What vintage,..??
krudville
Sorry. 1994 4 Winns 180 SE. 5.0. OMC Cobra Outdrive. Having a hard time getting the oil to fill from the bottom.
Lou C
Go and get a pump and do this the right way, if you do not, you will burn up your upper gears and cost yourself a couple grand at least. It is a closed system once all the drain/fill plugs are installed. Whatever the capacity of the drive is listed as you must get that much oil in it.
PS
there's more than one OMC Cobra drive, the original from 86-93, then the new joint venture series from 94 and up (same as a Volvo SX) the procedure for each is specific to that drive, so you need to know what the correct procedure is for the one you have.Cobra oil change.jpg
this is how you fill the original series, not from the very bottom like a Merc but from the second hole up, with the dipstick just laying in the top cover hole (this allows air to escape) get 2 qts in, then check with dipstick, if you need to add some you can add from the top. Pump slowly to allow air to escape. Then retighen dipstick. Also replace the fiber washers each time you change the oil. This one has 20+ years of salt water use and shifts like new, as bad as it looks!
PS a '94 could have either drive, the power package sometimes can be a year older than the boat itself. The original like this one is flat across the top of the upper gear housing, the later joint venture style has a hump on top same as a Volvo SX.
krudville
PS
there's more than one OMC Cobra drive, the original from 86-93, then the new joint venture series from 94 and up (same as a Volvo SX) the procedure for each is specific to that drive, so you need to know what the correct procedure is for the one you have.View attachment 409362
Thanks for all the info, Here is a picture of the outdrive, so i have the cone style not dog , correct? Also, I added 3 qts and it still does not come out the upper hole. I read that if i had the dog clutch I had to fill from the upper hole or I could have an air pocket, so I did put some oil in there. It started to come out from the water intake vents. I am screwed? How is this possible?outdrive.jpg
Horigan
By not coming out the upper hole you mean the overflow hole next to the shift mechanism? That's the correct place to check.
If you're getting oil out your water intake, the water passage between the lower and upper half of the drive is corroded/failed. You'll need to separate the drive to replace the transfer tube, as well as associated seals.
#47 below.
https://epc.brp.com/Index.aspx?lang...95/LOWER_GEARCASE/50FAPHUE_1995/85483716285/y
Lou C
Thanks for all the info, Here is a picture of the outdrive, so i have the cone style not dog , correct? Also, I added 3 qts and it still does not come out the upper hole. I read that if i had the dog clutch I had to fill from the upper hole or I could have an air pocket, so I did put some oil in there. It started to come out from the water intake vents. I am screwed? How is this possible?View attachment 409389
yep that's the joint venture cone clutch drive which for all practical purposes is the same as a Volvo SX of the same year.
