husaburg560
- May 20, 2005
- 29
I have a 82 merc pre alpha model 1 drive, that has a 1.65 ratio. problem is the shaft that the u- joints connect to is wore out and the seal is not sealing. I have already disassembled it. A friend of mine gave me a 1980 model pre alpha model 1 drive complete upper and lower units, they have very low hours on them, only thing is it has a 1.84 ratio. This is the only thing different about them. I switched them out. Now I have a slower top end, which makes sence of the higher drive ratio. I want to change the gears in the upper housing. When I do this should I use the shims out of the 1.65 drive or the shims out of the 1.84 drive? I have built several rear ends in cars before and have always set them up with 3 to 5 thousandths backlash on the gears and they run great. Just wondering what you guys think.
