labguy
- Apr 16, 2008
- 87
Hey Guys,
I have a 1986 Bayliner with a 3.0L 4 cyl OMC and a cobra outdrive. Heres my question: I pulled the boat out today to fire it up and it started fine. I had the water hooked up and as it was idling, I was checking over the engine for leaks, etc.. I looked over the back to make sure the prop was turning while in gear (outdrive down) and noticed a strong stream shooting out the upper left side of the outdrive. Didnt remember seeing that before, so I jumped out of the boat and noticed that it looked like there was a plug or something where the water was coming from at one time. I stuck my finger in to plug it up and it looked like more water started coming out of the transom, after circulating through the engine. Pulled my finger out and the stream from the transom diminished, so I shut the motor off. Is there suppose to be a plug there and if so, anyone know where I can get a replacement? Thanks for you help.
