Outdrive does not take in water anymore
89cruisers
Hi: I have a 1989 Cruisers Holiday 2670 with dual 3.7 4 cylinder Mercs. I started it up the other day like I usually do (put the muffs over the intake vents on the outdrives and turn on the water hose)and went to the helm after both engines were running a few minutes I started smelling somthing and the tempature guage was rising on the starboard engine so I turned them off and when I started the starboard one again water wasnt coming out of the holes where it usually does and it seems to over heat, this is a closed cooling system but I know that water is still needed to cool other components. Iv always started this boat and my past boats the same way before and never had a problem. do you know what is wrong. Thanks
dingbat
Re: Outdrive does not take in water anymore
When’s the last time you changed the water pump impeller?
89cruisers
Hi, I ment to put this in Mercruiser problems instead of mercury, but anyways I bought this boat recently and was sitting for years and never used and only has 150 hours on it, but the impeller was never replaced or even messed with Thanks
dingbat
I'd say you just identifed your problem. :)
