outboard wont shut off with key
regal sebring
Hi , Im new here hopefully Im posting this in the right area....( and I am ready for OMC sea drive bashing) I just replaced powerhead in a 1985 OMC Seadrive 1.6 litre outboard , no problems with removing old one and installing replacement , it fired right up first time ,which was a nice surprise ( i dont really have any experience with outboards)...but when i turned the key off motor wasnt shutting down , I had to pinch fuel line to get it to shut down ....any ideas????
NYBo
Re: outboard wont shut off with key
Welcome to iboats!:welcome:
Are you sure the replacement switch is compatible with an outboard and is properly connected to the magneto wires?
regal sebring
I never replaced switch i replaced powerhead and thats it?I switched 2 wires on ignition just to see if it would make a difference?.( thinking wiring on powerhead may be slightly different ) I put them back to where they were
Im thinking it can?t be anything too serious or it wouldn?t start and run
jhebert
Ensign
regal sebring
ok thats excellent thank u very much .. but why would new power head be different
NYBo
You must have something hooked up incorrectly under the cowl, or one of the magneto wires has broken between the powerhead and the ignition switch.
regal sebring
ok cool I?ll have a look , but as far as i know , I only connected main plug ( big rubber connector) , main starter lead and 2 ground wires
Silvertip
Start the engine and then disconnect the big harness plug. Insert a short jumper wire between the ignition kill terminal on the engine side harness and ground. If the engine dies the problem is in the helm side if the harness. If not, the problem is with the engine harness wiring.
merc150
Check or ground the ignition switch. I just had the same problem
