My 03 Johnson (J25TESTR) will shift fine except from reverse to neutral. It will go from reverse to forward and forward to neutral. What would cause this?
Going to work on that today, motor is at a relatives house (I live in an apt). The motor will go from N to R but when you shift to N from R it just stays in R even though it's in the N position. Then if you push it forward to F position it will shift right into F.
