Outboard weights
fireman57
Looking at an '83 evinrude 50hp to repower my boat. Do not have model number yet. Have a '91 25hp johnson on it now. Boat is rated for a 50 but I would really like a 40hp. Be that as it may, I sit a little low in the back now. I can and will redistribute some weight but can't find how much more the 50hp weighs than the 25. I can probably get this 50 in an even swap for my '76 9.9. Going to look at it Saturday and do a compression check. All the guy could tell me about it so far is that it is a 3 cylinder. I plan on new water pump and carb kits.
MCM
Re: Outboard weights
Hi, about 180-190 lbs, depending on whether its long or shrt shaft will make a little difference though.
fireman57
MCM the difference can't be that much. If the 50 wieghs 180-190 that doesn't really help me because I don't know what my 25 weighs. They are both long shaft but like you said won't make that much difference. Hope spring gets here early, I'm going nuts.
MCM
Sorry misunderstood what you were getting at, a 1980ish 25hp weighs between 105-120 aproximately, depending on features of course. Probably about the same for the '91 I would think.
rolmops
There is no 1983 3 cylinder 50 horse.They built one in 1968.Be real careful.Your 25 horse is about 120 pounds.If it is a 1983 2 cylinder 50 horse it is dependent on the type, about 190 pounds.If it is a 1968 it is about 250.
fireman57
Thanks guys, you know the drill. Can only relay what the guy tells me. Once I get a look at the model number I will know what it is. Just concerned about how much more weight I was looking at.
fireman57
Thanks R.Johnson. I can handle an extra 70 lbs. if that is what it turns out to be. I'm meeting him tomorrow am to do a compression test and get the proper year.
surlyjoe
I thought it was... OMC- big twins. APPROX 120-160#, 3cyls APPROX 160-220# and V-4's over 300#
