Outboard Value
medic4511
I;m looking to upgrade my outboard and was trying to find a value for the one I have. The NADA only shows 1996 motors as having 3 cyl. My 4 stroke 50hp has 4.
The serial # is 0G315548P.
Any help would be greatly appreciated
SM
JB
Re: Outboard Value
Either you have your engine model or the cylinder count confused, medic.
Nobody has made a 50hp 4 stroke with 4 cylinders, unless you count the Homelite/Bearcat 55s of the late 60s.
AMD Rules
Re: Outboard Value
Not true JB.... he has a 4 cylinder, 4-stroke Mercury circa 1996. Serial Number: 0G315548 Model Number: 1F50412SD.
As for its value, I cannot speculate. So many variables, such as hours of use, salt water, maintenance, abuse etc...
JB
Re: Outboard Value
Hmmmmm. Where is the error, AMD?
Did Brunswick/Yamaha make both 3 and 4 cylinder 50HP 4 strokes in 1996?
Is NADA wrong in listing the '96 50hp as a 3 cylinder?
Is his engine not a 50hp?
The model number you give does not match the style of model numbers in the NADA Guide. Is that the problem?
danpemby
Re: Outboard Value
Like the pawn broker said in Trading Places "I'll give you 50 Bucks" .....JK :devil:
AMD Rules
Re: Outboard Value
The error is that one may mistakenly assume NADA has 100% accurate/complete information. They did make 3cyl 50 Mercury 2-stroke motors .... BUT.... they also made 4cyl 50hp 4-stroke motors that year. Nada simply may not record that fact. The fact is, the Mercury website validates that Mercury did build the 4 cylinder 4-stroke, and also the 3 cylinder 2-stroke in the same year.
And Dan....$50 bid... lol... I think thats just a bit low :)
JB
Re: Outboard Value
So let me get this straight.
NADA lists a 50HP 4 stroke, 3 cylinder engine, Model 50ELPT, and a 2 stroke, 3 cylinder engine, Model ELPTO in 1996.
The 50ELPT 4 stroke is not a 3 cylinder, but a 4 cylinder. NADA error. Correct?
medic4511
Re: Outboard Value
Thanks for the clarification.
Still curious about value. I've only had it 1 year, always freshwater. As far as I am aware, the last owner ( In IA) only had it in freshwater as well. Recently sync'd carbs at tune up. Runs good. Starts well.
tashasdaddy
Re: Outboard Value
i think in my market, being 11 years old, and a 4 stroke. 2,000 - 2500 would be realistic. if it's is in top notch shape and cosmetics. cosmetics really hurt here. i'd keep this over that 90 that needs to be rebuilt.
