outboard tilt trim
maxmer
I have an Evinrude 40hp 4 stroke and the trim tilt will not bring the motor up. The trim works fine from the engine switch and throttle to move the engine down, but when trying to get the engine up with either the engine switch or throttle switch there is only a click noise at the engine. Thanks.
OBJ
Re: outboard tilt trim
Ahoy maxmer...welcome to iboats...<br /><br />Remove the cover from the engine. Look on the starboard side of the engine for the electric parts holder box. Remove the cover. To the left in the box you will see two relays. One is the TNT up relay (top) and the lower is the down relay. They will slip out of the holder. Pull the top one out and flick it with your finger and see if the engine will go up. If not, swap relays and try again. If it works in the up direction and not the down, replace the relay.<br /><br />Keep us posted...thanks.
maxmer
Thanks for the fast response, I will try it tomorrow. <br /><br />Maxmer
maxmer
Those are for a 2 stroke, this is a 4 stroke so it has relays. There is a blue and green wire coming from the tilt motor, one going to the up relay and one going to the down relay. I switched them and when I activated the up switch I got just a click agian and when I hit down the engine went up. I got a new relay for the up and I got the same results, What Now???
roscoe
Check the wires from the relays to the the pump.<br />Check for breaks or loose wires.
TPD211
Mine did the same thing recently.<br />After posting and getting great information from the forum I traced it to a corroded wire at the TnT motor on the bracket.<br />Also, my "socket" that plugs into the relay was loose so I tightened the fitting in the "socket" to make it contact better.<br /><br />The TnT works like a champ now.
