Outboard size for 21ft boat
jstcrzyengh
Hello,<br /><br />I am considering the conversion from I/O to outboard. Currently there is a 245hp 305 I/O in there, but it is an old OMC and repowering to a new I/O, for space reasons, is out. I am considering buying 1 new 250hp 4 stroke outboard, or two 150hp. My question is which would be best for fuel economy and overall performance. It is a fishing boat, not trying to win any sea records :) <br /><br />James
bigbrownbuku
Master Chief Petty Officer
Re: Outboard size for 21ft boat
2x F115 yamahas would be about as reliable/fuel economical a package as you could get and perform pretty much the same as you had.
jstcrzyengh
The boat is kind of heavy at 21.5ft long by 8.6ft wide. I do plan on moving the fuel tanks to mid boat to give a better weight reduction, but as I understand it even dual outboards will weigh less than the current electric shift OMC setup that is in there now... It will just be shifted back on the armstrong bracket. Is 115 too little? That's a 230hp at wide open throttle. Also forgot to mention this boat has a cabin, its not a center console and is a 71.<br /><br />James
Osprey
I have a 20' Graddy White 208 cuddy cabin which has a 1995 175 Yamaha. The boat is used offshore in all kinds of open ocean conditions and this engine/boat combination performs great. When / if I repower I would not go smaller, likely would look at the 200 4-stroke.<br /><br />Cruise speed is about 18-20 knots in moderate wind/chop conditions. Fuel economy is not great but about 2 miles per gallon.
rodbolt
jstcrzy<br /> you will have to inspect the transom carefully. most the old OMC hulls had very thin weak transoms like most inboard boats. the old OMC drives transmitted thrust to the stringers. modern power plants transmit it to the transome. have the transome looked at by a qualified engineer or hull specialist. this is not the place to price shop.
JB
Outboard Non-repair topic.
