outboard problem
BSmit
Does a 2005 50 hp yamaha 2 cylinder idle mostly on one cylinder
GoogieMan
Re: outboard problem
nope :) should be fireing on all cyl's :p
you might want to post your problem with more detailed info including the year, model and make etc so someone can give you accurate advice/help :D
BSmit
Moter has good compression good fire and plugs seem to be wet so getting gas
wellsc1
If carburated, it sounds like low speed or idling jet(s) is(are) dirty. Consider a carb cleaning and new plugs. Yes, check compression while the plugs are out.
99yam40
you still have not posted the model #
what are the compression #s.
How did you clean carbs?
Did you do a link and sync after reinstalling carbs?
Have you checked timing ?
Do you have a manual to give procedures and specs?
May need to check voltages to the CDI and coils with a DVA or peak reading DMM
