outboard oil vs inboard oil
dmsgms1967
by accident, I was looking for fourstroke outboard oil. The store attendant helped me and gave me four cycle inboard/sterndrive oil. Can I use this oil intead or should I return it for the outboard oil??? The engine is a mercury fourstroke 75 hp. Sorry I posted in the wrong spot. I'm new at this...second time's a charm! : )<br />Thanks for the advice! : )
jfm1
Re: outboard oil vs inboard oil
return the oil
JB
Outboard non-repair topic
LubeDude
If its the correct weight, its just fine, it probably has the new FCW Spec. That engine doesnt know that its on top of the outdrive instead of in front of it. ;)
imported_Curmudgeon
I suspect your engine calls for a certain spec oil. As long as that's what you have, it doesn't make a rat's patoot if it says ourboard, sterndrive, or inboard/outboard. It's the ratings and weight that matters, not the marketing.
Texasmark
Adding my 2 cents, both are 4 cycle marine engines, not oil burners, operating in a marine environment. Both are designed for continuous WOT running. If the rating is equal to or surpasses that required for the engine I wouldn't hesitate to run it.<br /><br />Mark
dmsgms1967
thanks for all the advice. I'm going to return it today.... Thanks again have a good weekend!
