Outboard motors 35-50 hp
rockland
When I asked my initial question, I should have mentioned that the reason the motor will be used at full throttle most of the time is because a 14 year old boy will be driving it, so a bigger engine would not be my answer. I need a way to either govern the throttle or find a very durable engine.
corm
Re: Outboard motors 35-50 hp
Hi Rockland,<br />I have a 15 yr old that runs a 1972 65 HP<br />Merc. I like the 4cyl 50,45,40 HP Mercs. The 3 cyl 40 and 50 HP Mercs are newer and just as dependable.They have more tourqe than the <br />4 cyl engines. Also the 49.9 cu in 50HP Merc,<br />is a propshaft rated version of the 65HP of<br />my Sons,much newer and improved.The new 50 Mercs are a 53 cu in engine. OMC 3 cyl 50 HP engines are good ones too. Just remember the water pump is the weakest point in engines today, so a water pressure gauge would be a good investment.<br />...good luck...corm
