calm like a bomb
- Jul 12, 2003
- 89
I recently removed the VRO tank and plugged the oil line on my 1989 70h.p. 3 cylinder engine. <br /> Runs fine using the 50:1 premix ratio.I noticed when I removed the 1.8 gallon VRO oil tank that the electrical line was never connected to the warning system.<br /> I ran the boat after the change around idle speed using the flush ears without any problems but I took it out fishing today(Caught some flounders) and had to listen to the no oil/low oil warning buzzer all day.I'm not sure how to correct this.Does the VRO pump itself have a sensor internally that would cause this?<br /> From everything I read prior to disconnecting the VRO it said just unhook it and plug the oil line.What can I do to stop the warning buzzer.<br /> The overheat buzzer works but the no oil/low oil will drive me nuts if I can't stop it.<br /> Any advice would be greatly appreciated.THANKS
