Ken Williams
- Oct 13, 2001
- 8
I have a 3cyl. 70hp 1980 johnson outboard. When put in water and drove 20mins to fishing spot motor ran great. After 1hour started motor and went to move, motor died when trying to power away. (motor started first time and idled perfect). This happened six times and I thought I would be stuck there. Motor started first time everytime and idled perfect untill I put in forward and tried to move away. Keept motor in neutral and reved engine using cold start lever. Reved-up perfect, put in forward gear and tried to acelerate, motor died. After five minutes started engine, put in forward and powered away. Drove for 15 minutes, everthing running great. Stopped and fished for 2 hours and the same thing happened again.Ambiant temperature was 27 C and did not have to use choke to start. Where and what should I look for to solve this problem ? Would apreciate any help. Thank you.
