Re: outboard gasoline question
I don't disagree with you about storing fuel with Stabil, Minnow, but: <br /><br />"Defeat the purpose"? How would draining the carb bowls prevent Stabil from stopping varnish formation? I think you meant that there is no varnish anyway so why drain the carbs?<br /><br />Unfortunately, Stabil does not prevent gas from evaporating and leaving the oil behind in the bowls. Draining the bowls does.<br /><br />In cooler climates or stored indoors that is only a small risk. Stored outdoors at 100F it is a real problem.
