Hi.
I have tried to fix this for a long time.
75 hp ELPTO trim tilt with single ram 3-wire connection
symptoms:
it goes down easily but it needs manual help the first 10-20 cm to go up - then it's doing better - but slow.
It has no problem to hold it's position except for slight loss when going long distance in high speed > 15 knots.
Slightly lower tone on the tilt engine when taking it up.
Actions already taken:
Added Quicksilver tilt fluid and have lifted the engine manually up and down 5 times to releas air with manual release valve out.
Disassambled tilt engine and added lubrication on both ends to electric engine (this helped a little and the engine runs at a higher speed)
Electricity checked (good battery, solenoids working)
symptoms:
