Outboard Drawings DXF/DWG
millsdes
Im looking for a 3 view drawing of an outboard in the 10hp range, preferably in an electronic format like DXF or DWG. Its for use in a 33' sailboat design where there is an outboard lifting in a well in the cockpit floor, and something between 9 and 15 hp will need to fit. Since it will be an owner supplied item, there wont be a single make/model, so any drawings will be good to get started with. <br /><br />Thanks if anyone has anything,<br /><br />Mark<br />info@mills-design.com
buttonhook
Re: Outboard Drawings DXF/DWG
are you looking for autocad drawings??? If so check 3dcafe they might have something
