cover is for a 175 hp johnson, there are vents on the top running twords the rear (weak crummy design) the vent broke in 3 parts
only could recover two,so i made up a filler peice with fiber glass.The cover is some kind of plastic How best to patch this in?
epoxy ?
also the cover has an inner liner (hard foam) can this be removed without butchering it,because some support from the inside would help a lot
epoxy ?
