For your first problem, stuck bolts, there are many threads on that, even in by me on taping, but the main thing you need is patience and heat. I use a mapp torch. For this issue, heat the bracket up by the bolt. Not red, just maybe 10 - 20 seconds ( i think the bracked is aluminum ). Then I spray pb blaster on the BOLT ( heat seems to suck it in the threads ) and then gently try to loosen. A little at a time is all you are looking for.
Do the non broken one first.
When that one is loose, work on the broken one. Get a vise grip in there as close to the transom as possible, and using the same paitent technique, loosen it only enough to remove the motor from the transom.
When it comes off, using the same technique, run it so you are tightening it ( vise grups would have destroyed the thread) to get it out.
Drilling out will be difficult.
