smsscuba
- Feb 15, 2009
- 126
I have a 1998 3 cylinder Johnson 35hp (BJ35ARLECR) that when put into foward gear, only gives low,limited revs on full throttle.I can get full revs when in neutral.
I removed all three sparkplugs and checked for spark.All three coils do produce a nice blue snapping spark, also I noticed that the top sparkplug was the only one that was slightly discoloured.The other two were still shiny (note these are brand new plugs).There was an oily mix on all three plugs, so they must be receiving oil/fuel mix.It wants to give more revs but something is holding her back.
Does the problem maybe lie within the carbs when under load.Can someone point out to me where to start looking? I have removed the carbs and looked in the bowls.All are spotlessly clean.
Maybe someone has had the same problem as me in the past.
Regards
Regards
