Outboard bogging down/picking up at full throttle
King6621
Hello all,
I have a 1995 70 hp Johnson outboard for the last month I have been fighting with the motor. When it is about to plan out on the water it bogs down then revs up right away and will keep doing that till I pull back on the throttle. Once you go to full throttle again it dose the same thing again. What i have had done to it so far: had a local shop put three new carb kits in it. I have put in three new spark plugs, three new coils, new fuel line. I am at a loss now should I try fuel pump next? Any help will be greatly appreciated. Thanks
Honorary Supreme Mariner
First thing to do is a compression test----Have you priced a new VRO pump lately ??
King6621
Compression test was done on the motor when the carbs were rebuilt and it has very good compression. I also mix the oil with my fuel.
