Outboard Air Cooled Disel Engines
nezih ahmet
I am trying to reach the attached outboard air cooled diesel engine manufacturer or dealers.
I think they are from India.
Any friend know aboat them?
Knightgang
Re: Outboard Air Cooled Disel Engines
Looks like something that the Cyote would use from ACME to chase the roadrunner...
allinmygarage
Looks to be this:
STAR BD10 Diesel Outboard Motor
10 HP, single cylinder, four stroke, air-cooled, transom operated, long shaft, rope start, manual tilt arrangement diesel outboard motor.
1. Propeller Shaft Power (kw/HP) : 7.35 / 10
2. Model : BD 10
3. Rated Speed (rpm) : 3,600
4. Bore/Stroke (mm) : 86 / 70
5. Type : Single Cyl, 4 Stroke, forced
air-cooling
6. Displacement (L) : 406 cc
7. Fuel consumption at Rated Speed (g/kw.h) : 285.7 ( Approx. 2.5 ltrs/hour)
8. Starting System : Manual / Electric
9. Gear Mode : Shaft gearing
10. Gear ratio : 2 : 1
11. Gear Shift : F ? N ? R
12. Net Weight (kg) : 72 kg
13. Overall Dimensions - L x W x H (mm) : 1,340 x 650 x 550
robert graham
Looks like a pretty good utility/commercial/work/fishing motor. Wonder if it's set up for salt water use? I'd like to see and hear this thing run.
jeeperman
Might half to go to Cuba to buy one, LOL.
The pic on the right looks like they will sell the outboard unit without the engine.
That would be cool to get then just use whatever horizontal shaft engine you want from a lawn tractor or whatever.
kenmyfam
Buy some ear plugs at the same time !!!
jeeperman
No prices anywhere and each google for that "Star BD10" leads to the same contact person.
Who has owned the contact website since 2005.
I bet what is show are one off prototypes and/or computer generated mockups.
Meaning none have yet been built and delivered anywhere.
Bob_VT
Okay..... I have to give this spammer credit! He suggested a product and everyone went and did research for it...... nice and subtle! :p
I will reveal to the iboats members that his post if from deep into a foreign country...... and I will leave it at that :rolleyes:
samo_ott
He also said "Any friend know aboat them?"
Not very Canadian...
