Trying to sort out my friend 2000 Merc opti 150. I get overheat alarm. Used to get the alarm only while sitting around at idle/trolling . Motor only used in fresh water.I did a lot of research on it and here's what I have done so far. Change impeller ,2 thermostats, 2 temp sensor, even c/o Merc mod to poppet valve, now alarms all the time water pressure is good coming out 3 psi , is there anything else that I'm overlooking . Or a way to unplug a wire to stop computer going into "safe mode" Thanks Frank
