I finally go the nerve up today to remove the drive, the drive shaft bellow had old gear oil ( Dark Brown)in color in it, I belive this was from 3 years ago when i paid a mechanic to put new seals all thru the drive & he didnt take the time to clean it out, I removed the gear oil dip stick to see what the gear oil in there looked like compare it to the oil i saw in shaft bellow, it was a yellowish color, which is why i belive the mechanic just didnt take the time to remove it.I felt the ginbal bearing & it had some ruffness, so I will try to remove it ,The shaft bellow looked to be ok to me, maybe Ill leave the oil in there to keep it soft, is this a bad ideal? I checked the U Joints other than some gear oil on them they were smooth so Ill probably just add some grease to them.The way i see it, I need the Gear housing to Pivot Gasket,the large rubber seal at the shaft entrance on the pivot housing,small rubber seal (i think this is the water port on the pivot side), the exhaust bellow has a slit on the pivot side at the top, I dont see where this could cause any problems.I thinks thats about it , any thing else i need to check? Ummm where is a good site to order these things from? Big thank you for all who got me this far ![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
