Ouch
Jd420214
This last weekend the wife and I took out our boat we just bought a 1987 Four Winns Candia 170 deck boat with a mercruiser 3.7 165 and alpha one out drive while moving over some to let another boat pass we hit a stump or something and bent the prop. I never had to replace a prop before as far as what one to use it had a solas 14x21 four blade on it should I just go back to that one we only cruise around with it and do some fishing with the grandkids but nothing fast and I dont plan on towing anything as far as tubes or a skier.
Just wanted to get and idea either go back to what was on it or something a little better for economical reasons.
Thanks
dave T. Michigan
SkiDad
i would put the same back on - that pitch and being a 4 blade sounds reasonable for what you want.
alldodge
Thanks
dave T. Michigan
Agree with mitzysman if your not having any issues or concerns, should be getting around 4400 rpm WOT. I would just fix the one you have, usually cheaper then buying another unless you find a used one.
Starcraft5834
what everyone said,, also if you fish.........think about getting a fish finder with shallow water alarm...I've got one on my Hummingbird 587 hd ci,, have it set for 6 feet.........it's nice to hear that chirp off if your not paying attention to your depth while drifting along or under power.............just a thought..
Jd420214
Thanks for the info guys I,m going to fix this one and keep it as a spare if they can fix it and get a new one ordered funny about the fish finder I just bought a new hummingbird and was going to install it but ran out of time it will get insatalled before I go out again.
Dave
