OSCO EXHAUST ELBOW for 1999 Volvo 4.3L?? Will it fit?
ss9940_2
Hi all!
I currently have an OSCO 50456 exhaust elbow in my stocky and it looks like it fits onto a V8 and V6 engine. The only trouble is that each current riser (on a 1999 4.3 GS engine) has a hose attached to it (it's an original Volvo, PN 3857402) and the osco has no hose inlet, only 2 painted brass plugs. I looked on their website, that's the ONLY riser for V8 and V6 engines they got.
Any suggestions? Take out the plugs & make a hose inlet or? Or is it impossible to use the osco exhaust elbow?
Thanx
Alex
Re: OSCO EXHAUST ELBOW for 1999 Volvo 4.3L?? Will it fit?
Ayuh,....... If it's the Right size,.... That's what I'd Do....
JCF350
That is what they (plugs) are there for.:)
ss9940_2
Thanx guys... The only thing that bothers me is that i don't know if the hole where the plug is sitting atm has threads or not. If i take the plug out and there are no threads, it will be a pain in the a** to get another plug that holds the water in.
GLM is different though. Their plugs can be easily removed - threaded holes.
Alex
jerryjerry05
The plugs should be threaded in.If they are the brass smooth freeze type dont take them out.Jerry
Ayuh,......
If you can put a Wrench On them or In them,.... They're Threaded......
If you Can't,....... They Ain't.......
