Re: Orificel Plug Tool
HI Rmsari. What year/model is the motor? I know I use a screw to remove the welch plugs from the carbs on my old '60s era Johnsons. Get a self-tapping, sheet metal screw and give it a few twists in to the plug and pull. It should come right out. The new plugs can then tapped down into place with a 3/8" socket extender or a flathead screwdriver. I try not buy and special/one use tools (coils alignment ring, shift rod bushing remover, orifice plug remover, etc...) if I can help it. Good luck.
