Ordering Throttle cable for replacement
karayj
So, I'm thinking of changing my throttle cable because my shifter seems to be extremely stiff and it makes it difficult when docking the boat. The first thing I am going to do is take my throttle shifter apart and check if it's dried out and it's just a grease problem, but if it isn't and I'm already in there, I might as well change the cables.
Now the plan was to separate the cabling from the linkage on the shifter and check the free play. If it is stiff, then I know it is the control box not the cables. (Add grease and pray)
I know the cable that goes from the linkage on the engine to the outdrive is smooth because I tested that last year. Next is to disconnect both cables from the shifter linkage at the engine and forward control and move the cables back and forth to see if I really do need to go through all this work. So, the question is how I find what the proper length for my 89 Regal. 18.9 Medallion I/O
