I did some reading of the post and I saw the full bridge rectifier replacement thread. I didn't see a follow up to see if it worked.Some of the links are not showing up explaining the setup. Does the full bridge work and should I use it or order a 'fier/reg? I found the cheapest one at surplus unlimited.com for 126 and it is made by cdi. Is it any good? Thanks Mike
