Options for Yamaha Trim Tilt
Reming870
I did some damage to my unit trying to remove frozen bolts and will likely now need a new assembly.
2003 Yamaha Trim Tilt Assembly for a 200 HP HPDI
As I look into I see other manufacturers are less expensive for the Showa units.
Are they the same Showa unit for Honda, Suzuki, Yamaha, etc...?
The damage was to unseen valve assembly in the top hole of the Gear Pump assembly removal. The three bolts holding the assembly to the main body broke off and I pried it off but got to happy with the screwdriver and jammed into a small tube with a ball check in it. I cant find the part anywhere online or in my book as all the diagrams exclude it.
I ask as it appears the Yamaha name tag holds more value than Honda or others for the Showa unit and they look identical.
