Options for Moving a Boat
I recently bought a cabin cruiser in TN and decided to move it closer to home in Indy. I don't trust my truck to tow the boat that distance.
The trailer(3 axle) that came w/ the boat doesn't have brakes installed and needs new tires along w/ other misc. items. I do not plan on using the trailer again other than to pull the boat out of the water for the winter and store it on the marina's property.
I'm new to boating so I thought I'd ask those w/ more experience on opinions for moving the boat.
Is it worth putting the money into the trailer to move the boat(still need to rent(borrow) a truck) or having a moving service haul the boat to the new lake. Other options?
The boat is a 1990 25' Maxum, 4,400lbs w/o trailer, ~6,000lbs w/ trailer.
Silvertip
Re: Options for Moving a Boat
I guess it comes down to economics, desire, and capability. Chances are all the states the trailer needs to pass through require brakes. Adding them is not all that difficult and in your case, electric would be the least expensive. You didn't tell us what make, year, model your truck is and what engine it has. If its a typical 3/4 ton or even a heavy duty half ton with a 350 CI engine it should be up to the task -- provided of course the vehicle has been properly maintained. If you don't feel up to the task or do not have any trailering experience you might find a friend who is experienced to make the trip with you. Between the two of you can gain some valuable experience from a knowledgeable friend. If you have deep pockets and simply want the boat moved, hire it done and pay the man.
My truck is a 01 Dakota, so I feel its pushing the limits for the trailer/boat combo. I don't mind towing the boat myself if I have the right equipment.
I haven't researched hiring someone to move it, so I didn't know the cost. I know I have at least $500 to put into the trailer to get it road worthy even if I do all the work myself. My Biggest concern was what needs done to put brakes on the trailer.
rickdb1boat
I'd have it hauled there(Flatbed, Etc) and tow the empty trailer myself...
Silvertip
If the axles have brake flanges on them, you simply add the backing plates (electric or hydraulic), new hubs, and the actuator. If the axles don't have the flanges, they can be purchased and added but they require welding so labor goes up considerably. Surge brake actuators replace the standard coupler. Electric brakes require an actuator in the truck. Electric is far easier to install since there is no hydraulic lines and fluid to contend with. Your Dakota would not be up to the task. But you could certainly rent a bigger truck.
PuddleJumper
Since you aren't going to use the trailer later for hauling, and it need at least $500 to make it roadworthy,I would suggest looking into flatbed hauler that would take boat and trailer . Much less time, hassle etc IMHO
bassboy1
Some of those moving companies are very expensive especially after loading and unloading.
