Optional charging system for 1970, 25 hp Johnson?
Bearcamp
Is there an optional charging system for 1969 through around 1974? Or do you just put the old solar panel on the hood? :)
seahorse5
Re: Optional charging system for 1970, 25 hp Johnson?
1977 thru 1982 - part #173358<br /><br /><br />See any J/E dealer<br /><br />There is no charging system kit for points and condenser ignition systems on the 25.
G DANE
Some of these came with a generator for 12 V lights, but the rectifier was missing. I parted one or two of them. As this model came with electric start too, they must have had a charging system too. I think I have a couple of the generator coils floating around, but as I am in Denmark it would be easyer for you to get one nearer by. I am sure the 1976 - 1981 rectifier could be used, and is easy to put on. Look for a stator plate on e-bay or elsewhere. The coil should just sit on the empty space across from ignition drive coil.
