Optimax lower unit/drive shaft question
Van Wildonher
Is there any way to know if it has a one piece drive shaft or two piece without removing the lower unit? It's a 2001 225.
Faztbullet
Re: Optimax lower unit/drive shaft question
The 3.0 liter "single bearing" unit is the only one that used a 2 piece shaft and that was mainly the 1998-01 models and some later CR models, all others use a 1 piece shaft....
Van Wildonher
Excuse my ignorance but are you saying there is no way to know without taking the lower off then? It's 3.0 liter and 2001 as far as I know.
My plan is to remove my two 200 johnsons and put this one on as a single until I find another one to match. (it may be up to or over a year) They have 25" shafts and it's a deep v hull so I believe I have to set the merc up for a 30" shaft. My plan is to get a lower unit from SEI because this one has a bent prop shaft, but I need to know if it's one piece or two. I wanted to get all of the stuff here at once that's why I'm trying to find out.
