opinions on rear motor mounts on my 7.4
jaxnjil
some might ahve noticed i have been changing gimble bearing and looking for a noise and slight viberation in my drive
i have been reading manual and checking trouble shooting guide.
i found this last night
16. Check for uneven mount height, or loose or soft
mounts. Make sure there is clearance between
flywheel housing and fiber washer. If no
clearance exists, mounts have probably sagged.
Install mounts correctly or replace, as
necessary.
well mine are setting on the washer. no pics i have to look with mirror.
the manual is pretty straight forward and i understand that. my question is-is this very common? has any one else run into this and any advice on how to make job easiser?
as always thanks ahead of time
john
Re: opinions on rear motor mounts on my 7.4
Ayuh,....
I wouldn't call it Common,...
But,...
There's been a BBC sitting on your's for the last 20 Years.....
Changing them is a matter of pulling the motor,+ popping the New 1s in.....
180shabah
...and that IS the easy way..
