Re: opinions on evinrude/johnson motors
I am a big fan of the 110 to 150hp motors you are seeing.When buying used always check several things...1. The compression , it should be in the 110 lbs range , and no more than a 10% difference between cylinders.2.The gearcase, check to see if there is water in the lower unit oil.3. You should take a test ride, motors very often run different when put under the strain of the boat under way. Happy Hunting! outboardboy
