Re: opinions on 83 century needed
The problem with the weep hole thing is that if it leaks long enough it also pitts the cam. Now you are putting cam and lifters in it too. The list goes on, and on.. The drive unit is likely to be and R drive which has been re-designed on the outside but is pre-Alpha one. We all agree the drive is not an issue. The engine can certainly be fixed as parts are available. But, is it economically feasible? These engines have inherent problems,(the charging system is another one) They are noisy, they vibrate and they are costly to fix. Ususally you can find a boat with a 4.3 v-6 in it for the same price and not have these issues. Now is your chance to do that. You can restore a Pinto too, but why?
